I have a dodge grand caravan 2012 and yesterday, the check engine light went on.
I know there's usually a way to get the error codes without an OBD device... I was able to do this on my old caravan by turning the ignition on 3 times (without starting the engine). Unfortunately, this trick doesn't seem to work on the 2012 grand caravan and I can't find anything about it in the owner manual.
Is it still possible to retrieve the code on a 2012?
The_Black_Smurf
  • 181
We can still read the code without a code reader with a key dance. Some people said the e-brake must be on in order to do this but the main problem in my case was about the key dance itself.
Basically, there's 4 ignition key positions:
  1. Off
  2. Accessories
  3. Run
  4. Start
When I was doing the key dance, I was doing it between position 1 and 3.
However, I just find out that the key dance has to be done between 2 and 3 (Run -> Accessories -> Run -> Accessories -> Run)
The_Black_Smurf
  • 181
