If you look under the hood of a WRX, the intake path is a little convoluted. Air enters a large channel near the hood latch that funnels diagonally across the front of the engine compartment. It then drops down into the fenderwell, passes through a bulbous silencer and then returns via the main intake channel heading towards the manifold.
So, here's the question: is the silencer in the intake path too restrictive for the turbocharged engine?
You'll often see sites talking about a silencer delete procedure which will definitely make more noise. What's not at all clear is whether removing any of this piping has any effect on total airflow.
Note: I'm not asking about power, tuning or whether the sound is cool / less so. The question is whether removing the silencer components will remove a restriction and increase net airflow.
Bob Cross
  • 24,537
  • 85
  • 166
Simple answer that all the forums seem to agree on, and that my garage also approves is that you will get better airflow to the manifold, however unless you also adjust your ECU, and potentially replace your Mass Airflow Sensor (depending on exactly what you are changing in the airflow path) then you may have problems.
I had the full Prodrive Performance Pack added to one of my Imprezas, and derestricting the inlet was only required for one of the performance boosts for the turbo. Without the PPP, this derestriction would not have given me any significant difference.
(I have had various modified Subarus over the years, so I chat to my local garage a lot :-)
tlhIngan
  • 12,200
  • 38
  • 71
Rory Alsop
  • 18,600
  • 60
  • 100
