My wife's Acura's alarm system was the most sensitive one I had ever run across. It was installed by the former owner, a professor in Princeton. Now we are in a little town with low crime so when the alarm system died, we danced on it's grave. Now it has returned like a shambling zombie, occasionally beeping and going off randomly (once while driving). That won't do. Is there anyway I can disable the alarm without just clipping the wires? The functions that prevent the car from starting haven't re-surfaced, just the alarm
UPDATE Well it is a third party alarm, unfortunately I cant find where it connects to the battery. I tried following some wires off the shock sensors but it enters into a rather full wire wrap. I also cant find any way of identifying the make and model of the alarm.
UPDATE 2 Well, good I guess. It got better. I still cant figure out why but it runs fine now. I won't delete this in case any answers current or future help anyone.
Bob Roberts
  • 785
  • 15
If it's a third-party alarm, you can probably just disconnect it from the battery. There should be a thinner red wire running from either the positive battery terminal or a positive auxiliary connection possibly near the battery.
If the alarm also came with remote-start, we'll have to discuss a different solution. Depending on the system you might need it un-wired completely if you need to go back to using the factory FOB for locking/unlocking doors (if you had one).
Cᴏʀʏ
  • 1,190
  • 16
The problem fixed itself. I can't figure out why or how. The only idea I have is either the battery was starting to drop (unlikely as there was no problem cranking) or there was a capacitor starting to fail.
tlhIngan
  • 12,200
  • 38
  • 71
Bob Roberts
  • 785
  • 15
