Yesterday I replaced the roller assembly in the left-side sliding door of my 2006 Honda Odyssey, because it had been sticking and not rolling very well. One of the white rollers was indeed shattered when I took it out, so it did need to be replaced.
However, the door is still sticking when we try to open it. A closer inspection shows that the top corner (toward the rear of the car) hits the door frame, causing the door to stop and return to the closed position. If we push (not very hard) on the top corner from inside the car, the door opens just fine. It always closes fine.
Has anyone run across this? Is there another piece that can be replaced, or an adjustment that can be made, to change the clearance at the top corner?
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
Ken Williams
  • 287
Check all the rollers, look at how the door sits compared to the body when closed, adjust the rollers as needed. if totally stuck either find a certified automotive tech or get a service manual. I used to buy individual manuals at Alldatadiy
Todd Shilt
Get another roller from the dealership or local junkyard. Until so your gonna have problems. Oh can be ordered from Ebay as well.
jayram1408
