I'm planning to buy a rear camera and parking sensor kits to install myself in a Honda Fit 2015. While I have no trouble making the proper electrical connections, I have no previous experience running cables from the back to the front of the car, so I'd like to ask the more experienced folks the most adequate path or way to do it.
Since the system uses the rearview mirror to display the rear camera image, I suspect the cable should go under the top panel cover (that panel between the car ceiling and the car interior - I don't know the proper name for that in english) and down through one of the lateral front columns somewhere close to the car floor. Then I wonder the cable should go between the door rubber and the floor covering, but I'm not sure. Any tips?
Thank you!
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
Claudio
  • 195
A common way to run cabling from the back of the car to the front is tucking it under the floor carpet near an edge, where passengers' feet don't frequently stomp.
For example you could route it along an edge next to the door, then through the B-pillar or A-pillar, around the windshield and to the rear view mirror.
