Its well known that using heat in a car is almost free (see for example here). It is also known that using the heat can reduce the engine temperature which otherwise needs to rely on water cooling. Since the water cooling has a price it is presumable that this would consume gas, possibly more gas then the cost of using the heat itself.
So my question is whether its actually more gas efficient to use the heat in your car then have it off and if so how big an impact can this have on gas efficiency? How big an impact this is, is also likely a function of the outside temperature, though I understand its likely hard to get that data...
Note: After forming this question I saw the same possibility posed in an answer to the linked question by JuannStrauss.
JeffDror
  • 123
Using the heater has no effect on fuel consumption. Using the heater won't lower the engine temperature because the thermostat will keep the engine temperature constant. It may actually use a tiny bit more gas from the electrical draw because of the blower motor.
vini_i
  • 16,115
  • 42
  • 64
-2
Nope, not one bit. As some others have mentioned, if anything you might need more gas to power the motor to blow the hot air into your car.
