I have a 2008 BMW 120d LCI with N47 engine. Recently was diagnosed with some oil leak on the rocker gasket near the injector area. Were advised to change the rocker gasket seals. So I did change the gasket and after changing and refitting the common rail, high pressure fuel pipe, injectors, head cover etc... The engine wont start, it does crank but just wont fire up. One should mention the car starts and drives perfectly fine before gasket change...
We hook it up with the BMW INPA diagnostic and the DDE was given 3 error memory.
4A64 Gluhkerze Zylinder 1. Ansteuerung
4A44 Gluhkerze Zylinder 3. Ansteuerung
3EC0 Nockenwellensensor, Signal
After some translations: 3EC0 was the camshaft position sensor 4A64, 4A44 was the Glow plug cylinder 1 and 3, driving(triggering?)
We are confident that the camshaft position sensor did plug back in as all connectors are connected, not sure on glow plug as we never removed or even touch the glow plug on the respective cylinders.
Hex key for 4A64 were:
4A 64 21 00 00 00 FF 28 48 A6 00 00 40 00 00 00
40 77 AC 02 00 00 00 3A EF 0C 00 0C 2B 0C 12 00
00 80 10 00 01 45 00 5C 51 EA 06 60 71 23 1B 31
42 8B B1 10 00 00 4F 48 F2 8B 0F 0C 2C 3E 27 00
00 00 10 00 01 50 00 37
Hex key for 4A44 were:
4A 44 61 00 00 00 FF 28 48 BD 09 B4 65 4D 3E 56
49 91 B0 10 13 47 4E 3F EE 76 28 0C 2C 80 34 00
00 00 10 00 01 4C 02 4A 51 EB 00 00 3A 00 00 00
41 77 AF 80 00 00 00 3B EF 0C 00 0C 2B 64 12 00
00 80 10 00 01 44 00 5A
Hex key for 3EC0 were:
3E C0 21 00 00 00 01 28 51 EB 01 EB 3A 00 59 52
41 64 AF 08 00 00 3B 3A 7F 0C 00 0C 2B 64 12 00
00 80 10 00 01 43 00 79
Please could somebody shed some light on this matter?
Many thanks
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
Gabriel
  • 173
The OP responded in the comments and stated the fix. He primed the motor with carb spray to get it going. Perhaps it had a mechanical fuel pump or needed the fuel rail primed in some way.
OP's response as the fix in comments below
Found out i need to spray some brake cleaner into the intake to prime the engine
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
