1991 Nissan Sentra XE, 1.6L engine, 5-speed manual trans, 78k miles.
I unexpectedly had to stop driving this Sentra and it's been sitting unstarted in my garage for the past 6-years. It ran great, no apparent problems, very low mileage.
It's been a great car and now that I can drive it again, I want to "recommission" it correctly.
Advice varies--some say you must drain+replace all fluids; some say replace only gas and coolant; some say replace gas only if it smells bad and has turned to varnish; some say to only drop a little oil in the cylinders before starting.
So this non-expert is confused. What is the minimum required to safely re-start this Sentra? I have a new battery; I'd like to re-start car and drive to repair shop for inspection. How can I do this without harming the car?
Thx for info--
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
tom9
  • 41
A bit of oil in the cylinders and then turn the engine over by hand 3 or four times would be a great idea. Then change the oil. The coolant, as long as it's full can be changed at the garage. The gas after 6 years is toast no and ifs or butts about it. Drain what you can then fill the tank with fresh stuff. Don't forget to change the fuel filter after going through a full tank of fuel. Everything else can be done in a case by case basis, fix whats broken.
vini_i
  • 16,115
  • 42
  • 64
