Honda Accord EX 1990, just bought.
When I make a tight turn, I sometimes hear a rhythmic clunking sound. This is supposed to be a tell-tale sign of a worn CV joint. But how do I know which side it's on?
When I had the front wheels off, I inspected the axle boots on both sides. I couldn't find any holes, but the axle assembly on one side is visibly older than the other. So I'm thinking that the old one is the prime suspect, but is there any way to be sure?
Mike Baranczak
  • 281
If It remember correctly, it is usually the inside wheel - i.e. if the noise is louder on sharp right turns, it's the right hand joint and vice versa.
The best way to tell is to jack up the car and support it on stands. Grasp the wheel in one hand and the driveshaft in the other, and try to rotate them in opposite directions. The worn one should feel 'looser' than the other. You can also try putting the wheel on full lock while the car is up, and rotating it by hand to try and feel the clonking.
Nick C
  • 28,941
  • 56
  • 109
I'd get someone to stand outside the vehicle while you test it in a parking lot and see if they can hear which side it's coming from. Or you could strap a recording device on each side and compare the loudness.
If you can't find the problem after doing that, I'd just let it go for a while until it gets worse. This would be bad advice if you want to fix the joint, in which case fixing it early would avoid further damage, but when rebuilt axles with a lifetime warranty cost about $60, I can't see why you'd want to go to the trouble.
Usually when turning right the left cv joint is the bad one and vice versa. I picked that up on my dodge caliber
For me, it's always been the outside wheel on a clunking turn that was the culprit (e.g right side if it clunks when turning left). However... they're both going to be about the same age, so just replace both; it's a quick job, and you know that it'll never need doing again.
PeteCon
  • 8,722
  • 17
  • 30
