While driving my '95 Chevy Blazer (4.3L V6) on the highway, I pulled off to use a rest stop. The engine was (and has) been running/starting well, and upon returning to leave, the engine would not start. The engine was turning over, but would not ignite. Here's what I know:
  • Battery is good, (even tried getting a jump just in case)
  • The fuel pump is active, (I can hear the pump when turning key to on position, and verified there was some pressure using fuel rail schrader valve - I didn't have a pressure gauge to deteremine how much pressure there was, but it was pressurized)
  • All 6 spark plugs, engine oil, tranny fuild, air & oil filter were replaced last month.
  • Ignition Coil is sending spark
Any ideas what could be up with it?
Thanks!
elliotwhitehead
  • 171
Well, I got it running! Just want to post an answer for anybody else that runs across this issue.
It ended up being the Fuel Pressure Regulator on the CPI Injector Spider.
This is a small and cheap ($35.00) part that is mounted on the side injector. and was very straightforward to replace. I simply had to remove the upper intake manifold, and all the necessary sensors/hoses/cables to access the injector spider, and replace the regulator.
To determine that the issue was in fact the fuel pressure regulator, and not the fuel pump, I first checked the fuel pressure and saw that it was very low. I then blocked the fuel return line to the gas tank, and checked the pressure again. Pressure was very high.
So basically, my regulator failed, and was sending all of the fuel directly back to the gas tank.
Swapped out the regulator, and she fired right up!
Hope this helps! Feel free to comment or message me if anybody has any questions!
elliotwhitehead
  • 171
