I just purchased a previously owned 2008 Chevrolet Malibu with 100,000 K on it.
Whenever I make a sharp left or right turn (making a 90 degree turn rather than a shallow turn), the front end makes a clunk sound after I pull out of the turn while centering the steering wheel. It also does this clunking when I accelerate hard or brake hard (this doesn't happen as frequently as turning).
The previous owner claims to have had the CV joints, brake pads and rotors changed before he decided to sell the car.
What could be the issue? How do I go about diagnosing it?
I'd appreciate any insight on this
- 2,206
- 2
- 17
- 26
- 71
- 2
It sounds to me like the previous owner suspected an outer CV joint (which was my first thought when you described the problem) and changing it didn't fix the issue.
I would double check that the outer CV joints look new and there is a good chance the problem could relate to one of the inner CV joints. Diagnosing the problem will likely be a case of jacking the car up and supporting in on axle stands (if you don't have any stands to support it, DO NOT try and do this with the car only on a jack) and spinning the wheels, feeling for up-down or left-right play and spinning the wheels at full lock. Also check for play in the drive shafts by again trying to "wiggle" them up/down and left/right.
One thing you may want to try. Perform a tight turn with the gearbox in Neutral and see if the noise still occurs. If it does it points to CV joints / driveshafts but if it doesn't it could be the output cups or differential on the gearbox.
- 23,464
- 2
- 41
- 92
