I have reworked all the carborators on the motorcycle. All seemed well but once it was put in gear, it stalled. What do I need to look for?
Asked
Active
Viewed 183 times
There is a sidestand switch that kills the motor if you attempt to put it into gear with the sidestand down, it's a safety measure. Check that switch at the top of your sidestand to see if the a mount bolt or nut has fallen out thereby loosening the switch and making the vehicle inoperable when you put it into gear.
DucatiKiller
- 32,976
- 22
- 150
- 267
