If I have the specifications for cylinder compression can I convert that to how much intake vacuum the engine should be pulling?
For example, if I have a 4 cylinder engine that is supposed to have about 180psi per cylinder can I convert that to an expected inches of mercury ( vacuum )?
Robert S. Barnes
  • 15,780
  • 72
  • 157
  • 249
As far as I'm aware, it cannot be done. Vacuum is a direct relation to valve lift and timing, does not relate to compression ratio. The vacuum is drawn during the intake stroke. In a 4-stroke (cycle) engine, the intake and compression events are completely separate.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
