I've failed my smog test 3 times in a row within a week. They told me it was the EGR. So I changed my EGR Valve, EGR Solenoid, and my EGR Pressure sensor. The vacuum lines running from the EGR Valve to the Solenoid are clean, no blockage.
I ran a OBD1 test, and the code 326 keeps popping up.
I checked the Catalytic Converter temps, before and after the Cat. Before it's about 300F and after, around 290F. I know it has to be hotter after to insure the pollutants are being cleaned before leaving the exhaust.
Any solutions?
Regards, Frank
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
Frank
  • 41
OBD1 326 indicates that the EGR pressure sensor is reading pressure values that are out of the range deemed to be normal.
Along with the results of your pre/post-cat temperature test, this is strong evidence that the catalytic converter is clogged.
The solution would be to replace the catalytic converter.
Zaid
  • 39,276
  • 50
  • 151
  • 294
