I recently had the clutch replaced on my car (well a friend did when I lent it to him). He replaced some other part he said was leaking - it looks very like the heater control valve when I google them on ebay (I think he is it was some water pump to my friend).
Anyway, it is now only blowing hot air. The mechanic is two hours away, so its a pain to back to get it checked. Assuming it is the heater control valve that was replaced, is there anything else I can check that might be causing it to blow hot air? Does it need any of the fluid levels topped up?
Update: I checked under the bonnet to look at the vacuum line as suggested, and noticed an electrical wire close to the window wipers that was unclipped. I need to find where it clips into now.
Nick C
  • 28,941
  • 56
  • 109
wobbily_col
  • 171
So it turns out I got conned by the mechanic. He knew I was in another town, so wouldn't get back to him.
I was told he had replaced the heater control valve, when in fact he had removed it and just put two plain tubes in its place.
wobbily_col
  • 171
