I recently failed an emissions test because my CAT and EVAP readiness monitors were "Not Ready" following a reset check engine light a few weeks back, which told me that the engine coolant wasn't running hot enough. I've confirmed this with a ODB-II scan tool.
According to pg 13 of this document (which is for a 2002, but I assume they are similar), my engine coolant temperature needs to be 176 degrees F for the CAT monitor to start running. My scanner is telling me that my ECT is running at ~160 degrees F.
I can't figure out if this means a sensor is busted, or something else (like cold weather) is causing the ECT to be that low. Can anyone recommend a next step that I might try on my own instead of taking it into the shop?
Duncan Rager
  • 153
In terms of possible root causes for failure, the following scenarios are likely culprits for a cooling system to run too cool:
  • A temperature sensor that's reporting lower-than-actual temperatures due to issues like drift/fouling/calibration.
  • A sticking thermostat that is flowing more coolant than necessary to maintain 176 °F.
  • Really cold ambient air temperature which prevents the system from settling down at the desired 176 °F.
The most likely culprit based on the information provided is a sticking thermostat:
  • If the temperature sensor malfunctions, one would observe negative temperatures with the scan tool, which in this case isn't happening. While temperature misrepresentation is a possibility, most temperature sensors have a tendency to either work well or not work at all.
  • A stuck-open thermostat will give slightly-below-par engine coolant temperatures, as is the case here.
  • More information is needed about the ambient air temperature in order to comment on it.
Zaid
  • 39,276
  • 50
  • 151
  • 294
