I have a Ford Escape 2014 and have a question about the climate "recirculation" button. This is the button that is supposed to enable the inside air to be recirculated.
On this vehicle this button has a 5 minute timer on it, meaning when you enable it, it stays on for 5 minutes and after that the AC starts pushing in outside air.
Now I would have thought that making this a simple on/off switch would have been a bit less effort.
Is there some practical reason why the recirculation has a timer, as opposed to just being an on/off switch?
6 Answers6
I also have a 2014 Escape, and the reason for this is actually explained in the owners manual.
The section under "Recirculated air", on. p.104, says the following:
Note: Recirculated air may turn off automatically (or be prevented from turning on) in all airflow modes except MAX A/C to reduce risk of fogging. Recirculated air may also turn on and off automatically in Panel and Panel and Floor airflow modes during hot weather in order to improve cooling efficiency.
Also on p.105 the manual says the following under "HINTS ON CONTROLLING THE INTERIOR CLIMATE":
Note: Prolonged use of recirculated air may cause the windows to fog up.
and
Note: To reduce humidity build-up inside your vehicle, do not drive with the system switched off or with recirculated air always switched on.
I have not had a need for the MAX A/C setting that much, where I live. With most of the other settings, recirculated air shuts down after 5 minutes. If you have a need for heat (instead of A/C), try enabling both the "Instrument Panel" (button "H" shown on manual p. 103) and "Floor" (button "I" shown on manual p. 103) mode at the same time. This seems to keep recirculation on much longer.
user100487
  • 236
My guess is to keep the a/c unit from icing up. By putting it on a timer you are inducing warmer air after 5 minutes.
mikes
  • 20,121
  • 27
  • 50
My 2006 Honda Civic doesn't have such a timer, but the owner's manual says:
The system should be left in fresh air mode under almost all conditions. Keeping the system in recirculation mode, particularly with the A/C off, can cause the windows to fog up. Switch to recirculation mode when driving through dusty or smoky conditions, then return to fresh air mode.
So with an ordinary switch, you have to remember to turn off recirculation when it's not needed, or your windows might start to fog. If you have a timer, you don't have to remember.
Nate Eldredge
  • 1,068
  • 14
  • 26
It is recommended that in high heat that you use the max AC and recirc buttions. This will not time out and makes the vehicles AC system much more efficient and use less energy and have a smaller chance of overheating the engine.
Mammy
In Texas recirculation is almost automatic in the summer. I've driven many miles this way with passengers and never any problem breathing
-2
You can think of this as a safety feature. It is not recommended to keep the recirculation button ON for long time, specially if there is more than 1 person in the car. You will use up all the oxygen. The car body is not perfectly sealed, so the actual chances of you dieing inside the car is pretty slim. But you would still feel symptoms of low oxygen.
With this automatic turn off, the car will draw fresh air after 5 minutes.
rana
  • 602
  • 26
