A full bottle of jewelry cleaning (links product and material safety data sheet below) broke in my car and went unnoticed for a few days. Now the car has a sulfur-like smell whenever I go into the car. It dissipates within a few minutes, but then returns very quickly once I leave the car.
The primary chemical components are alcohol ethoxylates, and can decompose into carbon monoxide, carbon dioxide nitrogen Oxides, sulfur oxides and other toxic gases.
I have cleaned the area and had the carpet (rear driver) shampooed from a car detailer, but still the smell remains.
What chemical compound can I use to neutralize the smell permanently (enter equilibrium)?
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
Brian
  • 233
Try rubbing a stainless steel item around the spill sight. Stainless steel has inert properties that take smells away. I use spoons..
https://en.m.wikipedia.org/wiki/Stainless_steel_soap
Also note you may have to pull back the carpet as it was a spilt fluid. There may still be remains of it under the carpet on the floorboards..
Dee
  • 697
  • 14
