The carburetor on my 2005 Honda Shadow Aero (VT750C) had a bad leak and flooded the air cleaner assembly with gasoline. The air filter was completely soaked with gas, so I let it air dry. Is my filter ruined, or is it okay now that it's dry?
Mauro
  • 2,665
  • 16
  • 24
Edwin
  • 479
  • 13
If it was just a normal paper filter it is fine. If it is a re-usable washable filter then then I would suggest a wash and oiling procedure according to the manufacturer instructions.
Elias
  • 300
The last vehicle in the USA to use a carb was the Susuki Jimmy in 1993. Your air filter element is bonded together with petro-chemical adhesives, and a lot of filters have a petro-chemical treatment to enhance thier performance. Soaking the filter in petrol can only be detrimental to the filter. Your best bet is to change the filter to avoid any possibility of it breaking pieces off and causing problems in the manifold or throttle body.
Allan Osborne
  • 6,749
  • 13
I think you must have to mention it on bike Because carburetor is being used in them mostly and if its leaked than you must first air dry the filter after oiling procedure and then check it out by putting it back. But it would be better to replace it.
