I took my car in for a service. Upon receiving it back I have to push the clutch in to it's absolute max before shifting gears. It wasn't like this before. If I can describe in terms of percentages it was as follow. The first 30% was freeplay. From 30 to 85 was actual clutch. The last 15% was freeplay.
How can this be adjusted?
If you have a clutch cable there is a nut to adjust where the cable mounts to the transmission. If you have hydraulic clutch there is not an adjustment, check your fluid level, low fluid could cause this, but this indicates an additional problem.
