I have just bought a citroen C3 and much to my horror was unable to turn the key in the ignition this evening. Had to wait about 10 minutes until it finally gave way.
Anyone else experienced a similar problem?
Is this an electrical problem, or is there something wrong with the key?
Richard Spencer
  • 51
When you turn the car off and remove the key, make sure the steering is not turned to one side. If you leave the car with the wheels turned you may load up the steering lock as the steering geometry tries to straighten up. You are able to get round this in the circumstances you describe by 'rocking' the steering wheel to relieve the loading on the lock as you turn the key to unlock it.
Allan Osborne
  • 6,749
  • 13
What worked really well for us, used preferably a rubber mallet, or a hammer and hit the key while in the engine and eventually it worked, perseverance works well with this, because it has worked for a lot of people on the Internet, saved our butts Lol
Tom
What you need to do is hold the key so you feel the pressure of it about to turn and wiggle steering wheel at same time with other hand . It happens to me.
