I have a 94 Pontiac Bonnyville that's leaking brake fluid. Recently the brake warning light came on and I noticed the fluid was low. I filled it again but it's slowly leaking.
The fluid is leaking at the point where the bottom of master cylinder meets the booster. There's an 1/8" wide bead of fluid dripping straight down and over the booster and then onto the ground. It doesn't appear that the fluid is leaking from the booster where it meets the firewall.
The brake pedal feels fine and doesn't sag to the floor while waiting in traffic. It doesn't stop like a Porsche but the stopping performance seems fine.
My question is, should I replace the booster as well as the master cylinder? How can I tell if the booster is bad?
This car is a ticking timebomb and i'm hoping to have it for less than 6 more months. However I don't want to be reckless to save a few bucks.
WrenchWacker
  • 133
Just need to replace the master cylinder, the booster should be fine. The piston in the master cylinder is bad and is leaking against the booster. That's the only place for the fluid to come out.
Any brake fluid leak what-so-ever should be repaired immediately. Your master cylinder requires to be changed before driving the vehicle at all on the road. That is unequivical.
Allan Osborne
  • 6,749
  • 13
