I'm troubleshooting what I believe is an engine misfire on my LS1 Chevy and want to rule out if I have bad ignition coils.
In order to do this I took out the ignition coils and measured the resistances across every possible combination of the four pins. The thought here was that any measurement that registers as an outlier in comparison to the rest would manifest itself in the readings.
I also purchased a new coil and took similar measurements.
The terminal nomenclature corresponds to what is in the diagram below:
Here are the raw measurements taken with a Fluke 87 V multimeter. All measurements are in kilo-ohms.
| Coil #1 | Coil #2 | Coil #3 | Coil #4 | Coil #5 | Coil #6 | Coil #7 | Coil #8 | New Coil #1
A-B | 31.71 | 29.30 | 29.64 | 34.19 | 28.14 | 31.47 | 34.08 | 32.89 | 26.77
A-C | 31.50 | 29.85 | 29.55 | 34.17 | 28.67 | 31.35 | 34.02 | 32.89 | 26.59
A-D | 33.67 | 33.7 | 33.56 | 34.09 | 33.52 | 33.89 | 61.00 | 62.10 | 31.29
B-C | 12.05 | 11.96 | 11.95 | 12.17 | 11.90 | 12.03 | 12.14 | 12.10 | 11.83
B-D | 88.70 | 83.10 | 84.80 | 94.00 | 82.40 | 87.20 | 95.10 | 95.00 | 73.9
C-D | 88.50 | 83.70 | 84.80 | 94.00 | 82.90 | 87.1 | 95.00 | 95.00 | 73.8
I realize that logging resistances may not reflect whether something is "bad", so I'd appreciate if someone could explain what the circuit diagram shows.
More information on the LS1 coil can be found here.
