I just picked up a new 2014 Ford Fusion and am planning on modifying the factory audio equipment. I've been searching around on some websites (The 12 Volt and various forums) and can't seem to find a reliable source for it. I tried buying a service manual and they were either not available or sold out. I don't want to wait for an online order if I don't have to.
Does anyone have a diagram or can point me in the right direction for one? All I really need are the speaker wire colors from behind the radio or if they're in the trunk somewhere, that'd be incredible.
Sage
  • 291
Most manufacturers tend to be fairly consistent with their stereo wiring, so it ought to be the same as other modern Fords. A quick googling reveals This site, which suggests the following:
Power Memory (+12v Constant) Green Yellow Ignition (+12v Switched) Yellow/Black Ground (-) Black or Fat Red Illumination Orange Dimmer Orange/White Power Antenna Blue (varies greatly)
Speakers Right Front (+) White/Green Right Front (-) Green/Orange Left Front (+) Orange/Green Left Front (-) Light Blue Right Rear (+) Pink/Blue Right Rear (-) Green/orange Left Rear (+) Pink/green Left Rear (-) Pink/Blue
With, of course, the usual disclaimers...
Nick C
  • 28,941
  • 56
  • 109
So I did some digging and managed to find a PDF of the entire wiring diagram for the 2014. I'll post a OneDrive link below for anyone who wants to download them. They also contain dashboard disassembly instructions and whatnot.
Amp Location: Right side of trunk. If you have the amp, it seems that the speaker wires are the same colors there as in the front of the vehicle.
Constant 12V (Radio) => white/brown
Radio Ignition => HS CAN
Radio Illumination => HS CAN
Amp Turn On => Purple/Red
Power Antenna => green/purple
FR Speaker + => White/violet stripe
FR Speaker - => White/orange stripe
FL Speaker + => White
FL Speaker - => White/brown stripe
RR Speaker + => Brown/white stripe
RR Speaker - => Brown/blue stripe
RL Speaker + => White/green stripe
RL Speaker - => Brown/yellow stripe
FL Tweeter + => Grey/orange stripe
FL Tweeter - => Green/orange stripe
FR Tweeter + => Violet/orange stripe
FR Tweeter - => Yellow/orange stripe
Front Center Speaker + => Green
Front Center Speaker - => Grey/yellow stripe
Rear Center Speaker + => Green/brown stripe
Rear Center Speaker - => Violet/brown stripe
Left Subwoofer + => Green/purple stripe
Left Subwoofer - => Gray
Right Subwoofer + => Purple
Right Subwoofer - => Yellow
http://1drv.ms/1lMkryJ
This is the link to the PDF that I'm referencing.
Sage
  • 291
If you pop off the trim and look at the wires, the two twisted together will be for the speakers. The power locks and windows will all run straight. Twisting speaker wires together helps with interference noise and is done on ford's. From factory.
justin
