I have a 2009 Holden Barina. I turned the car on to "Accessories" and the radio was working fine. I turned the car on, and now there is a noise coming from the speakers and no music. The same thing happens with the CD player. What happened and how can I fix this?
Nate Eldredge
  • 1,068
  • 14
  • 26
Amanda
On the face of it this should not happen. As have you white noise coming from your speakers it would seem that your radio/CD set has broken down internally. A check over from a competent auto electrician will determine if the fault is internal or down to any items such as mega-bass units external to the set, or even the aerial lead coming unplugged. A damaged external aerial could also cause this as far as the radio reception goes, but would not account for the CD not playing. Have you a set you could substitute with as a test.
Allan Osborne
  • 6,749
  • 13
Noise - means radio mode is working. Try to insert other CD, as your current CD might be damaged
Dzianis Yafimau
  • 211
If your car has points ignition, It may be a failed condenser. The sparking at the points creates interference, and your speaker wires could be inducting and amplifying the signals.
DrMeowmeow
  • 360
