I have an interesting problem on my VW Golf MK3 TDI.
Basically, sometimes the pressure cap on the coolant reservoir lets out some coolant.
Here's what I know:
  1. It happens when the car is under torque for a while (driving fully loaded on a motorway, or going up a small mountain).
  2. It doesn't happen when the car is not under torque (we drove about 1500km with light luggage, 2 people and a baby in the car, and no water was lost)
  3. The pressure is still there when the car has cooled down.
  4. There is no oil in the coolant
  5. There is no coolant in the oil.
  6. Thermostat works, I tested in a pan of water with a thermometer.
  7. Coolant reservoir (expansion tank) and cap are fine. I replaced them with new ones and the problem persisted
  8. The engine shows no signs of overheating. The thermostat remains at 90°C except of course if I idle the car for a while.
  9. The problem has remained the same for at least15000km
  10. The car is now at 227000km
  11. The water pump was replaced 2 years / 25000km ago
And here's what I think:
  • It can't be the cylinder head gasket because of 4, 5, and 9.
  • It can't be bubbles in the circuit because of 3.
  • It can't be the reservoir or pressure cap because of 7.
  • It can't be the thermostat because of 6, 8, and possibly 1, 2 and 3
I am at a complete loss at this point, as well as everybody I know.
Tom Macdonald
  • 445
tl;dr: Your radiator cap might be working as advertised and releasing a bit of overpressure.
The difference is points one and two is telling. In point two, you're explicitly staying out of boost on the turbo. Steady state cruising really doesn't require the turbo to spin up. In point one, you're explicitly relying on the turbo quite a bit. This is going to lead to:
  1. Hotter intake: air under compression heats up
  2. Hotter turbo-lubricating oil: the turbo gets hot compressing that air
  3. Hotter coolant: due to the oil->coolant heat exchanger
I'm going to assume that your engine temperature gauge is reading degrees C. That means that your indicated temperature of 90 is already approaching the boiling point of unmodified water at sea level pressure (like where I am right now - see there's the sea right over there! ;-). Your coolant isn't actually about to boil for a few reasons:
  1. It's not just water - it also has chemical additives that raise the boiling point.
  2. It's under pressue due to the radiator cap - this also raises the boiling point.
That pressurization isn't a magic spell, however. Eventually, the rising temperatures will lead to a pressure that exceeds the rating of the radiator cap, causing it to start to vent to atmosphere. This is on purpose: your cooling system isn't magic and you want any excess release to be controlled rather than explosive.
So, at this point, I think your vehicle is working approximately as intended. You have several options:
  1. You could decide this is not a problem. If the amount of coolant lost isn't a large amount, you could accept that every now and then you need to add coolant. This wouldn't be an unreasonable choice as you're driving an older vehicle.
  2. You could change your coolant. There are additives that you could introduce to the coolant that increase its ability to transfer heat.
  3. You could change your radiator cap. A radiator cap rated for a higher pressure will leak later.
Bob Cross
  • 24,537
  • 85
  • 166
Old topic, but just had the exact same problem on a 1.9tdi 110. The problem occured only under load, and certain driving conditions "pushing" the engine harder. We changed everything, cap, thermostat, resevoir, radiator!(someone suggested i could be clogged), oil heat exchanger, pipework, watter pump, and the heater matrix was eliminated at one point because it started to leak ( caused by the excessive pressure). Finaly i have decide to check the engine, and a very tiny leak was found between cylinder 2 and 3. A new headgasket and a new set of headbolts fix it permanently.
What is Your thermostat opening temperature? If it is 90 °C and if you live in country where temperature does not goes under negative Celsius, You can change thermostat with one that opens (for example) at 85 °C. If in winter temperature drops under 0 °C, then You can put that thermostat only in summer. You can also try thermostat with lower opening temperature and then test if that helps. I also do not know, if is available thermostat with lower opening temperature for Your car.
Guntis
  • 285
