12
Say someone has an easement across my land to access their property.
They have an easement, so I am not allowed to interfere with their use of my land. I can't stand there and block their way.
If two hundred other people come into my land to stop the easement holder from using the easement, can I tell the cops I am happy with those people being on my land? Or am I obligated to have them removed as trespassers? Or can the easement holder have them removed as trespassers because they are interfering with the actual use of the easement?
Michael Hall
  • 5,108
  • 41
interfect
  • 5,497
  • 30
  • 53
You're assuming that a police officer will accept your formulation of the question as being about whether you are "happy" or not about the presence of the protesters.
The most likely structure of the interaction is that your easement-holder will ring the police to say that a trespass is occuring which interferes with his rightful use of the land (via the easement).
The protesters may be asked whose permission they have to be present. They will either indicate that they have none, or they may say they have permission from you.
The question will then be put to you: are these visitors present with your permission, or are they indeed trespassers? Or, if they came onto the land without explicit permission, do you ratify their occupation of the land by granting them permission now, or are they present without your permission now?
If you grant permission, then you may become liable to your neighbour for frustrating the use of the easement. And if you do not grant permission, then the police may well remove the protest.
Steve
  • 3,383
  • 17
