13
See https://www.ams.org/journals/notices/202302/rnoti-p196.pdf?adat=February%202023
The head of the Purdue math department set a tenured professor’s salary to 0. This seems very strange to me and I have two questions.
First, does this violate minimum wage laws?
Second, is this constructive dismissal?
user48703
  • 139
Without commenting on the relatively strange situation itself, it is still useful to actually read what was actually said than what was described in a letter from a third person, even if the relayed information is technically true.
The supposed basis for the claim of a zero salary is from an email allegedly sent by the department head (appendix 15):
In short, you are not teaching in 2022/2023 and you have not submitted the required outline of your research or other engagement. I am very sorry that we cannot establish that you will be doing any work expected of a faculty member. Thus we cannot pay you. Starting with the Fall semester, your pay will be reduced to zero and you will be placed on unpaid personal leave.
Essentially, the professor is being put on an unpaid leave because allegedly he is not doing any work. Consequently, minimum wage laws are not engaged even if the professor is not exempt as teachers since he is not being required to do any work.
In the U.S., employers generally can do this (unless a work contract provides otherwise); in many circumstances, it is called being laid off (though the term has attracted a permanent connotation in parts of North America) or being suspended.
An indefinite unpaid leave can be considered constructive dismissal if the employer does not reasonably allow the employee to return to work. It may not be constructive dismissal if the unpaid leave is prescribed by binding employer policies or because the employee refuses to work (and the employer allows the employment relationship to continue). Even if it is constructive dismissal, it is not automatically wrongful.
xngtng
  • 6,766
  • 15
  • 31
This does indeed look like a constructive dismissal. Whether his offenses are serious enough to dismiss a tenured professor for cause is unclear.
If they have banned him from teaching any courses, however, as it appears that they have, I'm not sure if it would violate minimum wage laws as there are no hours in which he is required to work.
ohwilleke
  • 257,510
  • 16
  • 506
  • 896
The university has an official policy regarding termination of faculty. Though he is listed as a Profesor (not Assistant Professor), that only probably implies tenure – I will assume that he has tenure. The employment contract (which may and often is only implicit) will point to a vague assignment of duties that follow having the appointment. A person appointed to a faculty position receives a salary for the duration of the appointment – it is not an hourly job. Therefore, the university has a legal obligation to pay the faculty person for the duration of the appointment.
A tenured professor's appointment is "for life", or until terminated either by the employee, or according to the above rules, is terminated by the university. There is a formal procedure that must be followed, and failure to follow the procedure is pretty much the only way that a de-tenuring and firing decision will be overturned by the courts (violation of discrimination law is the other main way). The procedure does not allow the department chair to fire a faculty member. There is no indication that the required termination hearing was held.
It would be constructive dismissal to reduce an employee's salary to zero; dismissal without following university policies and procedures would be wrongful.
user6726
  • 217,973
  • 354
  • 589
