40
A fisherman is heading upstream in his boat, and sees a human corpse float past. Obviously even if it wasn't murder, it still warrants a 911 call because it was a death. The river however, is steadily moving the body away.
Can the fisherman move the body and avoid legal jeopardy because the intent was to preserve it as evidence?
You can make other scenarios I'm sure, but I chose this one as an example. Basically, the concept here is that doing nothing will possibly result in the total destruction of the body/evidence.
Razmode
  • 659
In this specific scenario, not only is it not a crime, failure to do so is a breach of proper maritime protocols and could be illegal.
A person manning a boat and sees a human in water in distress should immediately go to the rescue or recovery of the victim. This is commonly started by the crewman of the vessel who spots the body shouting "Man overboard" once... which triggers every crewman on the deck to also shout the same thing exactly once regardless of if they can see the man who is overboard (The idea is that the call is so all crew on the deck are not announcing the sighting but responding that they know there's an emergency situation in progress... and to muster to the appropriate situations). The boat's helmsman or pilot will then proceed to maneuver to recover the body in the water and bring it onboard the boat, (if traveling by sail, to then as soon as possible transfer to a motor powered vessel or to land which ever is quicker).
Additionally, should the boat have radio communication, the situation should trigger a mayday communication which will alert other vessels, regardless of purpose and local emergency services to the situation, with GPS tracking aiding all responders. Typically while underway at sea or in large bodies of water, all operators of watercraft are required to respond, regardless of actual purpose on the water (recall the famous "Miracle on the Hudson" incident where New York Ferry Operators were the actual first responders to get ALL passengers and crew off the crashed plane to land, where EMS and police services were waiting to deal with the survivors). Most boating licenses these days require a basic understanding of duties with maritime safety and if you come upon a situation while underway, you are a first responder automatically.
Remove the question of water and say that there is person who you are unsure of if they are alive or dead on dry land. Under law, you cannot be held liable for anything you do in the course of saving a life so long as you are acting within your competency to do so, and do not take actions you are not licensed to do as part of training, oversight, and regulations dictate, you cannot be sued for medical injuries inflicted on someone in the course of saving their life (called "Life over Limb"... that if the only way to save an unconscious person from death is to amputate a limb, you're not liable for cutting off the limb in question, so long as you are trained to do this. To a lesser extreme example, if CPR is performed right, you will break the victims ribs... since it's a question of keeping the person alive, the temporary pain and handicap of broken ribs is seen as acceptable).
As a lifeguard (for pools, I wasn't certified for "wilderness lifeguarding" but the differences in this respect were minimum) your first thing to do when getting in the water to fish out a swimmer in distress was to get them back to the pool deck before life efforts could occur (there are a few times where you had to start the life saving efforts in water, but I can count them on one hand, and one of those incidents was only after confirming your victim was conscious and even then you still were moving to get them out of the water asap... it's just asap would be a little bit longer. We also weren't trained to pronounce death. If it was so serious that CPR starts, you do not stop unless another guard or EMS relieve you.).
In these situations, there is proper evidence gathering procedures that will be used to establish what happened. For example, the first responders will be fingerprinted and prints in the areas touched for life saving efforts will be noted as part of the evidence. Additionally, paramedics, EMS and first responders will often alert police to any items of note they saw around the victim that were disturbed in the process of life saving efforts. The police may collect evidence from you to rule you out as a suspect (by showing the evidence on the body was consistent with applied life saving techniques) and to identify evidence not related to you at all (a pink fiber on the body that doesn't match any of your clothes means the body came into contact with the fibers from another source).
This also establishes "Chain of Custody" when you call the body in and stay with it and allow minimum contact with it (many larger ships will store the body in a locked room to keep crew and passenger contact to a minimum). Either way, so long as you tell the police everything you did in rescue and recovery, this isn't tampering with evidence on the face of it. If something that is inconsistent with your story comes up, it's not necessarily incriminating either... in the heat of the moment in a rescue and recovery effort, tunnel vision can form and you aren't expect to recall everything you did. Police should know this and understand that you were cooperating in what for most of the world is an unusual situation.
hszmv
  • 23,408
  • 42
  • 65
33
Using Florida as an example, this would be fine.
Tampering with evidence requires the intent to destroy, alter, or conceal it to impair its usefulness. The intent here was the exact opposite- there is no mens rea here and no crime has been committed.
Comic Sans Seraphim
  • 4,735
  • 15
  • 32
15
Based on what we were taught when I was an EMT in New York State, there would not be a problem. Seeing a body float by, you can't tell for certain that they are truly dead, so you would be perfectly justified in pulling them onboard/getting them to shore/rendering aid regardless of your level of training.
Face up/face down would not apply because, especially in cold water drowning, the brain can survive for 30+ minutes, if I recall correctly. If there was obvious decomposition, or obvious non-survivable trauma, e.g., missing head, then there is nothing that says you cannot act to preserve the body as evidence. As mentioned by @Studoku, regarding Florida, there is no criminal intent.
Probably the fisherman would prevail legally in the end, but he might get entangled in a very undesirable legal situation by recovering a corpse.
There was a real world case around a team of deep divers where the team even refused direct orders by the Coast Guard to recover a body. [Shadow Divers: The True Adventure of Two Americans Who Risked Everything to Solve One of the Last Mysteries of World War II, Robert Kurson]:
"Bring the body on board," ordered the dispatcher.
"Absolutely not," Kohler responded.
Kohler knew that by taking a body on his boad, he would be involved in a
prolonged investigation, and he had no time for that. Instead, he chose to
stay with the body and wait for the Coast Guard.
When the Coast Guard boat arrived, it radioed to Kohler.
"Pull the body onto your swim platform and follow us in."
"No way, " Kohler replied. "I'm going to let the body go unless you come and
take it."
Google Books Link
At some point, they had a corpse floating next to the boat (maybe from their team, I don't remember). They called the US Coast Guard, who tried to order them to load the corpse onto their boat.
The divers refused, because they expected the Coast Guard to order them to bring the corpse back to coast to a port of the Coast Guard's choice, then treat their boat as a crime scene etc., just because the Coast Guard wanted to avoid getting the corpse themselves. A very heated radio exchange ensued, with the Coast Guard trying to force them to recover the body, while the divers refused. In the end, the Coast Guard had to recover the body on their own.
I would not recover a body from the water if it was 100% certain the person was dead, e.g. from injuries not compatible with life.
  • you would probably eventually prevail in court under good Samaritan statutes, but you could be charged with obstruction, destruction of evidence etc.
  • it would turn your boat into a crime scene, you might be held up for a long time
  • you might be required to keep yourself available for questioning. A foreign jurisdiction might very well take your passport and jail you till you have been cleared
  • your DNA, fingerprints etc. might be taken, and your data will end up in police databases forever
  • it might be a biohazard situation. what if the corpse falls apart on your boat and the entrails spill out?
  • it could be traumatizing to be on a boat with a corpse, potentially for an extended time
Instead, you could mark the corpse with a buoy, maybe a GPS tracker, AIS (fishermen do use these to keep track of nets). Then get out of the way.
diver
  • 67
