Can the Complaint be amended?
In US District Court, can a plaintiff amend a complaint, more than 21
days after service, if extensions are granted to file an answer?
When a complaint requires correction of a mistake or misstatement,
which relates to the amount of relief they are entitled to, based upon
the same claim/cause of action, but more than 21 days have passed
since service was effected, does the granting of a defendant’s motion
of extension of time to answer, or subsequent extensions for the
purpose of negotiating settlement, provide any opportunity for the
plaintiff to amend the complaint, either with or without leave of
court, before the answer is filed?
Yes.
A Complaint can be amended once, as a matter of course, without leave of the court, at any time within twenty-one days of the filing of an answer or other responsive pleading (such as a motion to dismiss) is filed, pursuant to Federal Rule of Civil Procedure 15(a)(1)(B), and may also be filed later, with leave of the court, which should be liberally granted if filed within the time allowed by a Case Management Order in the case, pursuant to Federal Rule of Civil Procedure 15(a)(2) and Federal Rule of Civil Procedure 16(3)(b).
Doing so does extend the deadline for answering the Complaint to fourteen days after the amended answer is filed, however, pursuant to Federal Rule of Civil Procedure 15(a)(3).
Specifically, Federal Rule of Civil Procedure 15, which governs amendments of pleadings in U.S. District Courts, states in the pertinent part:
(a) Amendments Before Trial.
(1) Amending as a Matter of Course. A party may amend its pleading
once as a matter of course no later than:
(A) 21 days after serving it, or
(B) if the pleading is one to which a responsive pleading is required,
21 days after service of a responsive pleading or 21 days after
service of a motion under Rule 12(b), (e), or (f), whichever is
earlier.
(2) Other Amendments. In all other cases, a party may amend its
pleading only with the opposing party's written consent or the court's
leave. The court should freely give leave when justice so requires.
(3) Time to Respond. Unless the court orders otherwise, any required
response to an amended pleading must be made within the time remaining
to respond to the original pleading or within 14 days after service of
the amended pleading, whichever is later.
Should a status report be filed?
Can the mistake and intention/request to amend be brought to the
judges attention as part of the status report required, if the goal of
the plaintiff is to correct the record ASAP, in order to promote
judicial efficiency, to avoid potential negative impact or dismissal
based on the defendant’s exploitation of the mistake, or to stimulate
realistic negotiations (especially if a defendant recognizes the
mistake and they offer to settle for the full amount of relief sought,
hoping to avoid an increased judgement)?
If no previous amendment has been filed, the Complaint can be amended as a matter of course without court permission in this situation. Bringing the plaintiff's desire to amend the complaint to the attention of the judge in a status report is not required, and is probably not desirable, in this situation.
Filing a status report would take more time than simply filing an amended complaint and would give the other side in the case notice that gives the other side a window of time to try to take some sort of action before the complaint is amended. Ultimately, the other side probably couldn't do anything that would seriously impair the plaintiff's case, but the other side could take some action which could delay the case or increase the effort required for the plaintiff to litigate the case (e.g. by filing a motion to dismiss the case whose status has to be clarified with court proceedings).
