While starting programming my ESP8266 to get continuously changing data (car position) from a server, I encountered a problem: I can't get the ESP8266 to receive the data from the server more than 3 times/second.
The data rate would be preferably 15 times/second. The received data is a string of 47 elements.
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
// WiFi information
const char WIFI_SSID[] = "my-wlan";
const char WIFI_PSK[] = "123qwe123qwe";
// Remote site information
const char http_site[] = "10.13.137.144";
const int http_port = 8080;
// Pin definitions
const int LED_PIN = 16;
// Global variables
WiFiClient client;
String readString, readString1 ;
int x=0;
byte led_statuss = 0;
void setup() {
// Set up serial console to read web page
Serial.begin(115200);
Serial.print("Thing GET Example");
// Set up LED for debugging
pinMode(LED_PIN, OUTPUT);
// Connect to WiFi
connectWiFi();
//////////////////////////loop///////////////////////////////////////
void loop() {
int time=millis();
getPage();
delay(100);
// If there are incoming bytes, print them
int lines_received = 0;
while(client.available()) {
String line = client.readStringUntil('\n');
if (lines_received == 7) {
String k =(line.substring(0,line.length())); // removes headers from the server response
Serial.println(k); // prints the raw data
int time1 = millis()-time;
Serial.print("Time is ");
Serial.println(time1); // shows how much time the function takes
lines_received++;
// Do nothing
//Serial.println("Finished Thing GET test");
// Attempt to connect toFi///////////////////////////////////////////////////////////
void connectWiFi() {
byte led_status = 0;
// Set WiFi mode to station (client)
WiFi.mode(WIFI_STA);
// Initiate connection with SSID and PSK
WiFi.begin(WIFI_SSID, WIFI_PSK);
// Blink LED while we wait for WiFi connection
while ( WiFi.status() != WL_CONNECTED ) {
digitalWrite(LED_PIN, led_status);
led_status ^= 0x01;
delay(100);
// Turn LED on when we are connected
digitalWrite(LED_PIN, HIGH);
// Perform an HTTP GET request to a remote page//////////////////////////////////////////
bool getPage() {
// Attempt to make a connection to the remote server
if ( !client.connect(http_site, http_port) ) {
return false;
// Make an HTTP GET request
//client.print("GET /cars" + "HTTP/1.1 \r\n" + "Host: " + "10.13.137.154" + "\r\n" + "Connection: close\r\n\r\n");
client.println("GET /cars HTTP/1.1");
client.print("Host: ");
client.println(http_site);
client.println("Connection: Close");
client.println();
delay(100); //some put delay, but why and how long?
return true;
We do a GET request from the server and we filter out the raw data from the headers and the responses are:
Thing GET Example1;62.91;43.55;190.03;5.59;20.00;44.26;861503022
Time is 228
1;62.91;43.55;190.04;0.00;20.00;43.79;861503920
Time is 926
1;62.91;43.55;190.03;0.00;20.00;44.26;861504988
Time is 1050
1;62.91;43.55;190.08;5.76;20.00;43.83;861505980
Time is 1011
1;62.91;43.55;190.07;0.00;20.00;43.82;861506983
Time is 992
1;62.91;43.55;190.04;0.00;20.00;43.79;861508012
Time is 1036
1;62.91;43.55;190.11;0.00;20.00;43.86;861510045
Time is 2020
1;62.91;43.55;190.05;0.00;20.00;43.80;861510274
Time is 222
1;62.91;43.55;190.07;0.00;20.00;43.82;861511306
Time is 1026
1;62.91;43.55;190.07;0.00;20.00;43.82;861512410
Time is 1108
1;62.91;43.55;190.04;0.00;20.00;43.79;861512605
Time is 219
1;62.91;43.55;190.03;0.00;20.00;44.26;861512840
Time is 214
1;62.91;43.55;190.06;0.00;20.00;43.81;861513842
Time is 996
It seems that the ESP can't get the GET responses faster. Time is in ms. I did manage to get it to work evenly if the delays are around 400 ms.
What would be the best way how to improve the speed of the procedure?
