During a range testing for Ra-02 Ai SX1278 LORA, I noticed a strange behavior. Following are the settings that I used. Tested distance is 1200m line of sight. We tested the setup for different antenna combinations. All antennas are same type and have a 2dbi gain.
| Tx Antenna. | Rx Antenna | RSSI. | SNR |
| 433 MHz | 433 MHz | -130 | -10 |
| 915 MHz | 915 MHz | -110 | 4 |
| 2.4 GHz | 2.4 GHz | -108 | 8 |
These are the configuration settings.
433.0, // freq
31.25, // bw
9, // sf
7, // cr
RADIOLIB_SX127X_SYNC_WORD, // syncWord
17, // power 2 - 17dbm
8, // preambleLength
0); // gain
As you can understand, our modulation frequency is 433MHz so we should get a higher RSSI and SNR with the 433MHz antenna but we get a higher gain for high frequency antennas. Does anyone has a proper explanation for this?
