I'm not sure where you got your classification, it seems a bit weird to me.
There are dozens of 13.56 MHz RFID card types and sub-types, but some of the most common are:
NTAG devices (could be actual cards, or take many other forms, especially stickers). Those are used mostly to "publish" an URL which can be read by a mobile phone for instance (like you would print a QR Code containing an URL), though like QR Codes, you could have all sors of data in there. NTAG devices have capacities in the dozens or hundreds of bytes. There are originally rewritable, but you can write-protect them after programming them.
Mifare cards. There are quite a few models (Classic, Ultralight, DESFire...) and submodels (EV1/EV2/EV3, 1K/2K/4K/8K, etc.). Those have storage capabilities, and depending on the models, various modes of encryption and protection. Mostly used for access badges and for ticketing in transportation systems.
EMV payment cards (credit cards, debit cards...). Usually dual mode (contact + contactless), they can contain multiple applications, perform PIN verification (and self-disable once you have reached the maximum number of wrong PINs), hold a balance, perform crypto operations (digital signatures...).
e-Passports and some ID cards and driver's licenses.
Smartphone can also emulate quite a few of the above (as well as read quite a few of the above).
There are quite a few other RFID cards and devices, but the above are probably the most common, at least in Europe and North America (in Japan and a few other countries you'll also find Felica, Icode, and others). Not all are actually NFC (NFC is only a subset of all 13.56 MHz RFID cards).
The UID is present on all those cards, it is used in the anti-collision protocol. The UID is supposed to be static, unique and non-rewritable, but of course you now have random UIDs, re-used UIDs, and carts with modifiable UID (used to clone existing cards).
Using the UID to identify a card is very simple and used a lot for non-security-sensitive applications. As soon as you need security, you can just forget about that, you'll need something more secure.
Most cards can store a lot more information, it can range from a few bytes to tens of thousands. There are often ways to protect the data (e.g. on most Mifare cards you can save data which is protected and can only be read if you have the relevant keys). Some cards like payment cards and the like can use asymmetric crypto and store a private key which you can read (but you can check the card knows the correct key by sending a challenge and verifying the signature it returns with the matching public key/certificate).
To answer your questions specifically:
Is it possible to read more data?
Yes, there are commands to do so.
if so - what is the nature of this data? (and notably - is it random data?)
It would be the data you stored there. Before you write any data, depending on the card, it could be just 0s or some other fixed pattern, or just random data. Just think of it as a (very small) hard drive or USB stick. It holds blocks, you write data to it, and you can later read it back (taking into account various levels of protections if there are any).
Some cards may also have other read-only data, though the details vary from card to card, you would have to check the data sheet for the specific model. Other cards may have dynamic data as well (e.g. number of activations).
Some cards are able to generate dynamic data with a counter and a signature involving that counter, other data, and a private key (so one can even on some of them generate a dynamic URL which changes at each read). Again, specific to each type of card.
Are there different cards with the possibility to write "only UID" or "UID and more data"?
I'm not aware of any card on which you could only write the UID. Most cards to not allow changing the UID. And there is nearly always more data you can write to. However many cards can be write-protected, so you can write data, then set the card to read-only (either permanently or until you provide a password you set at the same time, depending on the card). Read-only mode can be set either card-wide or per block, depending on the device.
Is it possible to programmatically query/guess the type of card?
Very generally it can quite difficult given the very large number of card types but there are ways to do it for specific cards. See for instance the MIFARE type identification procedure
For some cards/tags you can use the NFC TagInfo by NXP app on Android which will try to determine the tag type and provide more information, though results vary quite a bit depending on the type of card/tag. There is also an iOS version but it provides less information, and has probably more limited compatibility.
