I am using a Tattile camera with ANPR and trying to use it with customized SW following ANPR_DeveloperGuide_E.pdf.
I managed to access all functionality (getting data, setting data, requests including getting images) except getting plate numbers. I am doing
- Enable Engine
- Start Trigger
- Get Check List (A or B)
and for each command I got positive response and there are no errors but the "Get Check List" command return 0 detected plate numbers.
Using the webinterface one can see that the number plate is clearly visible and centered.
