I have a device with Tasmota 11.1.0 with two SSIDs configured. The device is now connecting to SSID2 and I would like it takes SSID1 as default one. When I replace SSID2 with a non-existing name, then tasmota switches to SSID1 without problem. I can't find any command to switch to SSID1 and set it as default. I tried in command line: ssid1 but it does nothing. Also WifiConfig.
The documentation is not clear to me
Ssid<x> <x> = 1..2
<value> = set AP<x> Wi-Fi SSID and restart
1 = reset AP<x> Wi-Fi SSID to firmware default (STA_SSID1 or STA_SSID2) and restart
SSID are limited to 32 characters. Do not use special characters or white spaces in the SSID
How to setup default (preferred) SSID on Tasmota so when both are working desired one is used?
