Can I turn on/off my electrical socket "Gosund SP1-C" from local network ? (via telnet, for example. Like it happened with Yeelight bulbs) I see that 80, 8080 and 5353 ports are opened but can't found any suggestion what command I can send to Gosand. (also, I failed with other tutorials, because this device don't use 'tuya app' and connect directly to Apple_cloud/homeKit/home_app and looks like can't be added/appear in 'tuya app'. And that why I can't get id/key that can be used for connecting to Gosund via cli)
Asked
Active
Viewed 669 times
I found the way to manage my Gosund SP1-C outlet via Homa Assistant server and/or Home Assistant app.
I need:
pairing with Gosund SP1-C outlet via Home App and iPhone
- this add my Gosund SP1-C outlet to 'local' network + iCloud (or HomeKit server)remove Gosund SP1-C outlet from Apple Home App
- this remove my Gosund SP1-C from iCloud (or HomeKit server) but it should stay paired to the 'local' networkNow
Home Assistantserver able to found automaticallyGosund SP1-Coutlet and you just need to pairing with it via code that located on QR label that attached to theGosund SP1-Coutlet (or it's box).- * both of them: `Home Assistant` server and `Gosund SP1-C` outlet need to be in same local networkHomeKit Controllerintegration need to be installed already onHome Assistantserverhttp://ip_adress_of_your_server:8123/config/integrations
After this steps you can able to control your HomeKit compatible-only Gosund SP1-C outlet via Android phone or browser via Home Assistant server web-page
https://www.home-assistant.io/integrations/homekit_controller/
user216
- 11
- 2
