Please look at this sketch for ESP32. It does nothing but:
- connects to WiFi
- connects to AWS MQTT
- subscribes to the
/get/acceptedtopic - every 5 s publish an empty message to the
/gettopic to retrieve the shadow file
#include <SPIFFS.h>
#include <WiFi.h>
#include <WiFiClientSecure.h>
#define ETH_CLK_MODE ETH_CLOCK_GPIO17_OUT
#define ETH_PHY_POWER 12
#include <ETH.h>
#include <SSLClient.h>
#include <PubSubClient.h>
#define MQTT_PACKET_SIZE 4096
#define ID "myid"
WiFiClientSecure networkClient;
PubSubClient pubsub;
char rootCA;
char privateKey;
char *certificate;
unsigned long old_millis = 0;
bool readFile(const char path, char *buffer)
File file = SPIFFS.open(path);
size_t size = file.size();
buffer = (char ) malloc(size + 1);
char p = buffer;
while(file.available()) p++ = file.read();
p = '\0';
return true;
void callback(char topic, byte payload, unsigned int length)
Serial.print("Received ");
Serial.print(length);
Serial.print(" bytes @ ");
Serial.println(topic);
Serial.println((char *) payload);
void setup()
Serial.begin(115200);
SPIFFS.begin();
WiFi.mode(WIFI_STA);
WiFi.begin("myssid", "mypassword");
while (WiFi.status() != WL_CONNECTED)
Serial.println(".");
delay(1000);
Serial.println(WiFi.localIP());
char filename[64];
readFile("/AmazonRootCA1.pem", &rootCA);
networkClient.setCACert(rootCA);
sprintf(filename, "/%s-cert.pem.crt", ID);
readFile(filename, &certificate);
networkClient.setCertificate(certificate);
sprintf(filename, "/%s-private.pem.key", ID);
readFile(filename, &privateKey);
networkClient.setPrivateKey(privateKey);
pubsub.setServer("myendpoint-ats.iot.us-east-2.amazonaws.com", 8883);
pubsub.setBufferSize(MQTT_PACKET_SIZE);
pubsub.setClient(networkClient);
pubsub.setCallback(callback);
old_millis = millis();
void loop()
char topic[64];
if (pubsub.connected())
pubsub.loop();
if (millis() - old_millis > 5000)
sprintf(topic, "$aws/things/%s/shadow/name/module-1/get", ID);
pubsub.publish(topic, "");
Serial.print("Publish to ");
else
Serial.print("State ");
Serial.println(pubsub.state());
if (pubsub.connect(ID))
Serial.println("MQTT connected");
sprintf(topic, "$aws/things/%s/shadow/name/module-1/get/accepted", ID);
if (pubsub.subscribe(topic)) Serial.print("Subscribed to: ");
else Serial.print("Error while subscribing to: ");
else
Serial.print("failed, rc=");
delay(1000);
Here the output:
09:52:35.752 -> .
09:52:36.745 -> .
09:52:37.738 -> 192.168.1.41
09:52:37.837 -> State -1
09:52:40.716 -> MQTT connected
09:52:40.716 -> Subscribed to: $aws/things/myid/shadow/name/module-1/get/accepted
09:52:42.834 -> Publish to $aws/things/myid/shadow/name/module-1/get
09:52:42.967 -> State -3
09:52:45.945 -> MQTT connected
09:52:45.945 -> Subscribed to: $aws/things/myid/shadow/name/module-1/get/accepted
09:52:47.831 -> Publish to $aws/things/myid/shadow/name/module-1/get
09:52:47.997 -> State -3
09:52:50.975 -> MQTT connected
09:52:50.975 -> Subscribed to: $aws/things/myid/shadow/name/module-1/get/accepted
09:52:52.828 -> Publish to $aws/things/myid/shadow/name/module-1/get
09:52:52.993 -> State -3
Every time it publish the message the MQTT connection is lost. Why? What is my mistake?
