I'm trying to connect on a broker with the following script
#!/user/bin/env python
import paho.mqtt.client as mqtt
import random
import requests
import warnings
import LoggingManager
logger = LoggingManager.log_setup()
logger.info("Start Working")
my_client_id = f'python-mqtt-{random.randint(0, 1000)}'
# method = "websockets"
my_endpoint = "wss://psmart-test-api.aegean.gr/ws/"
# port = 443
# keepalive = 60
key = "ea75d54ea85b54ba5cde22ffb31090f9b2cbaeba8ad6eef1be575bfae89f56d3"
url_login = "https://psmart-test-auth.aegean.gr/auth/refresh_session"
warnings.filterwarnings('ignore', message='Unverified HTTPS request')
def myNewlogin(key, url_login):
loginobj = '''{ "token": "%s" }''' % (key)
loginHeaders = {'Content-Type': 'application/json'}
login_response = requests.request("POST", url_login, data=loginobj, headers=loginHeaders, verify=False)
table = {}
table["status_code"] = login_response.status_code
if (login_response.status_code == 200):
result = login_response.json()
mytoken = result["token"]
table["token"] = mytoken
else:
table["token"] = login_response.text
return (table)
is_connected = False
# The callback for when the client receives a CONNACK response from the server.
def on_connect(client, userdata, flags, rc):
print("Connected with result code " + str(rc))
global is_connected
is_connected = True
# Subscribing in on_connect() means that if we lose the connection and
# reconnect then subscriptions will be renewed.
# client.subscribe("$SYS/#")
# client.subscribe("org/TERIADE/K4XKF6UT/Temperature")
# The callback for when a PUBLISH message is received from the server.
def on_message(client, userdata, msg):
print(msg.topic + " " + str(msg.payload))
def on_disconnect(client, userdata, rc):
print("Disconnected")
# authenticate to take username
# user = str(myNewlogin(key, url_login))
# print(user)
login = myNewlogin(key, url_login)
if (login["status_code"] == 200): # if we can login
# print("mylogin 200")
logger.info("mylogin 200")
else:
# print(login)
logger.info("mylogin" + str(login["status_code"]))
# Create a client instance
client = mqtt.Client(my_client_id, transport='websockets')
# Register callbacks
client.on_connect = on_connect
client.on_message = on_message
# client.tls_set(ca_certs="https://psmart-api.aegean.gr/roots.pem")
# client.tls_set()
# Set userid and password
client.username_pw_set(login["token"])
# Connect
client.connect(my_endpoint, 443, 60)
client.loop_start()
publish_interval = 5
value = 0
while 1 == 1:
if is_connected == True:
print('hello')
else:
print("still waiting for connection")
time.sleep(publish_interval)
# Blocking call that processes network traffic, dispatches callbacks and
# handles reconnecting.
# Other loop*() functions are available that give a threaded interface and a
# manual interface.
# client.loop_forever()
# while 1:
# Publish a message every second
# time.sleep(1)
and I'm getting the following error
Traceback (most recent call last):
File "mqtt_client_psmart.py", line 91, in <module>
File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 941, in connect
return self.reconnect()
File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 1075, in reconnect
sock = self._create_socket_connection()
File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 3546, in _create_socket_connection
return socket.create_connection(addr, source_address=source, timeout=self._keepalive)
File "/usr/lib/python3.7/socket.py", line 707, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File "/usr/lib/python3.7/socket.py", line 748, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -2] Name or service not known
I can't find a solution. Any ideas? Thanks in advance
After @hardillb help, I made the following changes:
# Configure network encryption and authentication options. Enables SSL/TLS support.
client.tls_set()
Set websocket connection options.
client.ws_set_options(path="/ws", headers=None)
Connect
client.connect('psmart-test-api.aegean.gr', 443, 60)
The code is running now... I get still waiting for connection but that another issue....
