When sending MQTT messages, first message arrives within 2 seconds and subsequent messages sent within less than 20 secs from first message, arrive in about 0.5 second.
I would like to speed up those “first” messages and wonder if there's a way to keep the line hot without bombarding the client with unnecessary keep alive kind of messages.
I am running Mosquitto version 2.0.4 on Ubuntu 18.04.5 LTS which has almost no load, it only runs the broker and has no subscribers other than the one I am testing.
The client is an Arduino 1400 MKR GSM connected over 3G network, it connects to the broker and then loops on the message receive callback without any other tasks.
mosquitto.conf
pid_file /var/run/mosquitto/mosquitto.pid
persistence true persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log log_timestamp true log_timestamp_format %Y-%m-%d %H:%M:%S log_type all
include_dir /etc/mosquitto/conf.d
default.conf
allow_anonymous false
password_file /etc/mosquitto/passwd
listener 1883 protocol mqtt
listener 8883 protocol mqtt
listener 8000 protocol websockets
listener 9001 protocol websockets
listener 8083 protocol websockets cafile /etc/nginx-sp/ssl/xxx.combined_crt keyfile /etc/nginx-sp/ssl/xxx.key certfile /etc/nginx-sp/ssl/xxx.combined_crt
EDIT
Publisher code Using phpMQTT:
$mqtt = new phpMQTT($server, $port, $client_id);
    if ($mqtt->connect(true, NULL, $username, $password)) {
        $mqtt->publish($topic, $payload, 0);
        $mqtt->close();
        return 1;
Bence Kaulics
  • 7,843
  • 42
  • 90
Nino
  • 131
I wonder if the publishing client is doing its entire sequence of connect and security handshakes at the time when you want to send your first message. The connect and handshakes can take some time over cellular networks, especially 3G. Perhaps you can share the code of the publisher. That would help.
In regards to your second question, Mosquitto does have keep alive functionality. The keepalive parameter is sometimes a parameter in the connect method of the MQTT client library, such as Mosquitto.
kalyanswaroop
  • 1,208
  • 16
