I am working on a project which sensed four speed by using hall sensor attached to wheel by using raspberry pi.
I have wrote program for that only issue with that it gives fairly good results when wrote program for one sensor, and when using all sensor (using interrupt add_event_detect by pull up resistor), readings are quite different either one or for every sensor. One thing I noticed is that it gives good results when I run 4 program for 4 sensor differently. So I conclude that may be the issue is to convert code to multithread or something schedule task one sensor to another until first is finished.
One more issue it never gives 0 value even I unplugged sensor (I know the reason behind it there is no statement in code to do that) actually I don't know much coding hence help me to figure out this problem.
import RPi.GPIO as GPIO
import time
import requests
import sys
import csv
GPIO.setmode(GPIO.BCM) GPIO.setwarnings(False)
distance1 = 0 distance2 = 0 distance3 = 0 distance4 = 0
rps1 = 0.00 rps2 = 0.00 rps3 = 0.00 rps4 = 0.00
speed1 = 0.00 speed2 = 0.00 speed3 = 0.00 speed4 = 0.00
start_time1 = 0.00 start_time2 = 0.00 start_time3 = 0.00 start_time4 = 0.00
end_time1 = 0.00 end_time2 = 0.00 end_time3 = 0.00 end_time4 = 0.00
wheel_c = 2.874
hall1 = 2 hall2 = 3 hall3 = 20 hall4 = 21 elapse1 = 0.00 elapse2 = 0.00 elapse3 = 0.00 elapse4 = 0.00
GPIO.setup(hall1, GPIO.IN, pull_up_down = GPIO.PUD_DOWN) GPIO.setup(hall2, GPIO.IN, pull_up_down = GPIO.PUD_DOWN) GPIO.setup(hall3, GPIO.IN, pull_up_down = GPIO.PUD_DOWN) GPIO.setup(hall4, GPIO.IN, pull_up_down = GPIO.PUD_DOWN)
def get_pulse1(number): global elapse1, distance1, start_time1, end_time1, speed1, rps1 while GPIO.input(hall1) == 0: start_time1 = time.time()
while GPIO.input(hall1) == 1:
    end_time1 = time.time()
elapse1 = end_time1 - start_time1
rps1 = (1/elapse1) / 2
speed1 = (rps1*1293)/10000
distance1 += 1.293 * elapse1
def get_pulse2(number): global elapse2,distance2,start_time2,end_time2,speed2,rps2 while GPIO.input(hall2) == 0: start_time2 = time.time()
while GPIO.input(hall2) == 1:
    end_time2 = time.time()
elapse2 = end_time2 - start_time2
rps2 = (1/elapse2) / 2
speed2 = (rps2*1293)/10000
distance2 += 1.293 * elapse2
def get_pulse3(number): global elapse3,distance3,start_time3,end_time3,speed3,rps3 while GPIO.input(hall3) == 0: start_time3 = time.time()
while GPIO.input(hall3) == 1:
    end_time3 = time.time()
elapse3 = end_time3 - start_time3
rps3 = (1/elapse3) / 2
speed3 = (rps3*1293)/10000
distance3 += 1.293 * elapse3
def get_pulse4(number): global elapse4,distance4,start_time4,end_time4,speed4,rps4 while GPIO.input(hall4) == 0: start_time4 = time.time()
while GPIO.input(hall4) == 1:
    end_time4 = time.time()
elapse4 = end_time4 - start_time4
rps4 = (1/elapse4) / 2
speed4 = (rps4*1294)/10000
distance4 += 1.294 * elapse4
try: print('1 seconds...') time.sleep(1)
GPIO.add_event_detect(hall1,GPIO.FALLING,callback = get_pulse1,bouncetime=20)
GPIO.add_event_detect(hall2,GPIO.FALLING,callback = get_pulse2,bouncetime=20)
GPIO.add_event_detect(hall3,GPIO.FALLING,callback = get_pulse3,bouncetime=20)
GPIO.add_event_detect(hall4,GPIO.FALLING,callback = get_pulse4,bouncetime=20)
while True:
    print(speed1,speed2,speed3,speed4)
    time.sleep(2) #to reduce CPU load, print every 100 milliseconds
    data = str(speed1) + "@" + str(speed2) + "@" + str(speed3) + "@" + str(speed4)
    with open('test.csv', "a") as file:
        writer = csv.writer(file)
        writer.writerow([time.ctime(),speed1,distance1,speed2,distance2,speed3,distance3,speed4,distance4])
    try:
        r = requests.post('http://dgprojects.co.in/Park/Hardware.php',params={'sensor': data})
        a = (r.text[0:1500])
    except:
        print("exeption");
except KeyboardInterrupt: print('You have pressed Ctrl+C! How dare you stopped this beautiful thing?!') GPIO.cleanup()
anonymous2
  • 4,902
  • 22
  • 49
Try this: Have event processors for the falling and rising events for each GPIO. So, you'll have 8 event processors instead of 4. In the event processors, just store the timestamp of the event. In your main loop, do the time diff and speed calc of each wheel. You could decide the speed is zero if there have been no events in the last x sec.
kalyanswaroop
  • 1,208
  • 16
