I am trying to send messages from my Arduino to my Raspberry pi. But I don't understand why the pi isn't receiving the messages.
On the Arduino side I'm using an Arduino UNO with a Dragino Lora/GPS shield, using the Radiohead library.
On the Pi side, the Upotronics LoRa hat for the pi zero and a pi zero, which is based on a RFM95 chip. And on the software side I'm using the Raspi Lora library.
I wrote a couple of simple programs just to test the connection, and I can send messages from the raspberry to the Arduino, but not the other way around.
Am I making a mistake in the code on either sending the data from the Arduino or receiving it on the raspberry that prevents this?
Code for the Arduino: This one sends data it gets from serial port and awaits radio input when nothing is available.
#include <SPI.h>
#include <RH_RF95.h>
RH_RF95 rf95;
void setup(){ Serial.begin(9600); if (rf95.init()){ Serial.println("Init Success"); } else { Serial.println("Init Failed"); } if (rf95.setFrequency(868)) Serial.println("Freq set for 868Mhz"); if (!rf95.setModemConfig(RH_RF95::Bw125Cr45Sf128)) Serial.println("Invalid modem");
Serial.println("Send serial data to echo it through radio"); }
void loop(){ uint8_t data[100]; uint8_t len; if (Serial.available()){ delay(20); int i = 0; while (Serial.available() && i < sizeof(data)-1){ data[i] = Serial.read(); i++; data[i] = 0; } rf95.setModeTx(); if(rf95.send(data,i)) { Serial.print("Message sent: "); Serial.println((char *) data); Serial.println(i); } else { Serial.println("Failure to send"); } }
if (rf95.available()) { if (rf95.recv((uint8_t )data,&len)){ Serial.println("Got it"); Serial.println((char )data); Serial.println(len); } } }
Raspberry pi code: This one just initializes the lora instance, I run it on the interactive console and in theory it should print data, but as much as I tried I haven't managed to catch an IRQ on any of the pins when I send a message.
from raspi_lora import LoRa, ModemConfig
This is our callback function that runs when a message is received
def on_recv(payload): print("From:", payload.header_from) print("Received:", payload.message) print("RSSI: {}; SNR: {}".format(payload.rssi, payload.snr))
lora = LoRa(0, 25, 2,freq=868, receive_all=True, modem_config=ModemConfig.Bw125Cr45Sf128) lora.on_recv = on_recv
lora.set_mode_rx()
Bence Kaulics
  • 7,843
  • 42
  • 90
metichi
  • 241
I figured it out. Turns out there was a bug in the raspi_lora library I used for my python code. It is so that, if you are not specifically sending to the device address or have receive_all=True, it will do nothing with the messages.
If you plan to use the raspi_lora library you should replace line 268 in the lora.py file with
if (self._this_address != header_to) and ((header_to != BROADCAST_ADDRESS) or (self._receive_all is False)):
Bence Kaulics
  • 7,843
  • 42
  • 90
metichi
  • 241
