12
I have a standard wall switch connected to an input on a Shelly relay, call it A. I have a second Shelly relay (call it B) across the house that has a light connected to the relay output.
Using the Shelly Cloud software, can the switch input on A control the relay on B?
longneck
  • 221
Yes, just using the built-in local software.
Background: Shelly relays can be sent http commands to switch them on and off. This is documented at https://shelly.cloud/documents/developers/ddd_communication.pdf
First, on relay B, find the local network address of the device. This is in Settings -> Device Information, and will be something like 192.168.x.y where x and y are two numbers between 0 and 254. Make a note of these numbers.
Now, on relay A, go into Actions and find the "Button switched on URL" and "Button switched off URL" lines.
Enable these, and add a URL. It will be something like: http://192.168.x.y/relay/0/?turn=on to switch the other device on.
If you don't want relay A to change anything connected directly, you can change its button type to "Detached Switch"
jymbob
  • 151
Here's how I did it: https://youtu.be/yNspcmSY-60
I Got the Shelly IP & MAC addresses from my router's "Connected Devices" page. Then I reserved (or you can make static routes) for the Shelly's least my router changes the assigned address on restart and mess up my scripts.
My Scripts are: In Actions
http://192.168.0.(Your Address Here)/relay/0?turn=on
http://192.168.0.(Your Address Here)/relay/0?turn=off
IMPORTANT: When you start your Shelly's for the first time UPDATE THE FIRMWARE. I didn't and did some configurations on the Shelly's web-server that really looked wrong. Then after a firmware update everything got way better but I had to do a factory reset and start from scratch because my first script was still there but I couldn't find it to edit/delete it.
I used the following 2x Actions in my "Detached" 1Plus to control my Dimmer2 ON/OFF state remotely and it still doesn't work. I can hear the 1Plus clicking ON/OFF but the Dimmer2 output is unaffected. Any thoughts?
http://192.168.216.107/relay/0?turn=on http://192.168.216.107/relay/0?turn=off "192.168.216.107" is the address of my Dimmer2.
