I can successfully flash my ESP32-CAM to do the blink demo but when I try to run the code below I get the following error (b/t the asterisks/bar.)
It seems the "Serial Camera Control Bus" (SCCB) is not able to connect to write to the buffer in memory. I tried to double check the code I borrowed to see if pointer were coded with typos or errors but to be honest that is a little outside of my comprehension. Then there is the "camera_init(): Failed to set frame size" and the "esp_camera_init() failure error 0x20002"
After trying to trouble shoot and research online it seems as if the camera pins aren't connecting properly or there is a failure to write to memory.
If anyone has a better grasp on C++ and could help me further troubleshoot or point me in the right direction I would greatly appreciate it.
[E][sccb.c:154] SCCB_Write(): SCCB_Write Failed addr:0x30, reg:0xe1, data:0x67, ret:263
[E][sccb.c:154] SCCB_Write(): SCCB_Write Failed addr:0x30, reg:0xff, data:0x01, ret:263
[E][camera.c:1215] camera_init(): Failed to set frame size
[E][camera.c:1270] esp_camera_init(): Camera init failed with error 0x20002
Code to send a JPEG image to my Apache server using php://input so they can be stored on my computer:
#include "esp_http_client.h"
#include "esp_camera.h"
#include "WiFi.h"
#include "Arduino.h"
const char* ssid = "************";
const char* password = "***************";
int capture_interval = 20000; // Microseconds between captures
const char *post_url = "***************/wifi/index.php";
// Location where images are POSTED
bool internet_connected = false;
long current_millis;
long last_capture_millis = 0;
// CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
void setup()
Serial.begin(115200);
if (init_wifi()) { // Connected to WiFi
internet_connected = true;
Serial.println("Internet connected");
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
//init with high specs to pre-allocate larger buffers
if (psramFound()) {
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
} else {
config.frame_size = FRAMESIZE_SVGA;
config.fb_count = 1;
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
bool init_wifi()
int connAttempts = 0;
Serial.println("\r\nConnecting to: " + String(ssid));
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED ) {
delay(500);
Serial.print(".");
if (connAttempts > 10) return false;
connAttempts++;
return true;
esp_err_t _http_event_handler(esp_http_client_event_t *evt)
switch (evt->event_id) {
case HTTP_EVENT_ERROR:
Serial.println("HTTP_EVENT_ERROR");
break;
case HTTP_EVENT_ON_CONNECTED:
Serial.println("HTTP_EVENT_ON_CONNECTED");
break;
case HTTP_EVENT_HEADER_SENT:
Serial.println("HTTP_EVENT_HEADER_SENT");
break;
case HTTP_EVENT_ON_HEADER:
Serial.println();
Serial.printf("HTTP_EVENT_ON_HEADER, key=%s, value=%s", evt->header_key, evt->header_value);
break;
case HTTP_EVENT_ON_DATA:
Serial.println();
Serial.printf("HTTP_EVENT_ON_DATA, len=%d", evt->data_len);
if (!esp_http_client_is_chunked_response(evt->client)) {
// Write out data
// printf("%.*s", evt->data_len, (char*)evt->data);
break;
case HTTP_EVENT_ON_FINISH:
Serial.println("");
Serial.println("HTTP_EVENT_ON_FINISH");
break;
case HTTP_EVENT_DISCONNECTED:
Serial.println("HTTP_EVENT_DISCONNECTED");
break;
return ESP_OK;
static esp_err_t take_send_photo()
Serial.println("Taking picture...");
camera_fb_t *fb = NULL;
esp_err_t res = ESP_OK;
fb = esp_camera_fb_get();
if (!fb) {
Serial.println("Camera capture failed");
return ESP_FAIL;
esp_http_client_handle_t http_client;
esp_http_client_config_t config_client = {0};
config_client.url = post_url;
config_client.event_handler = _http_event_handler;
config_client.method = HTTP_METHOD_POST;
http_client = esp_http_client_init(&config_client);
esp_http_client_set_post_field(http_client, (const char *)fb->buf, fb->len);
esp_http_client_set_header(http_client, "Content-Type", "image/jpg");
esp_err_t err = esp_http_client_perform(http_client);
if (err == ESP_OK) {
Serial.print("esp_http_client_get_status_code: ");
Serial.println(esp_http_client_get_status_code(http_client));
esp_http_client_cleanup(http_client);
esp_camera_fb_return(fb);
void loop()
// TODO check Wifi and reconnect if needed
current_millis = millis();
if (current_millis - last_capture_millis > capture_interval) { // Take another picture
last_capture_millis = millis();
take_send_photo();
