I bought an orange pi zero plus and want to make a wifi access point that passes all traffic of the connected devices through tor.
Simply I wanted a dev board that has gigabit ethernet and wifi for access point, and is as cheap as possible.
I want to create a secure pathway through tor. So I installed Tails(not specifically but for the sake of its features) on my sd card and tried to turn my Pi on, but nothing, not even led's glow. I am sure that power adapter is working fine and same is ethernet cable.
Does Tails has to do with any of this? I assumed that most of lightweight distros can run pretty fine on new dev boards. Should I install armbian instead of tails? if yes, then why won't tails work?
K_lash96
  • 43
Are you sure Tails supports the Orange Pi?
The System requirements page implies it only supports x86_64 based hardware:
https://tails.boum.org/doc/about/requirements/index.en.html
hardillb
  • 12,813
  • 34
Some Orange Pi components are in the mainline kernel and some are not. To have a full running Linux OS, you should use armbian. If you want to use another distro than Debian/Ubuntu, you need to use Yocto in order to build your own image. There is a recipe for the Allwinner used in the Orange Pi Zero.
Citrullin
  • 156
