I'm using a Wemos mini, to switch on the light.
I'm trying to figure out how to combine IFTTT and Sunset and Sunrise from Weather underground to trigger the lights ON.
All examples I find, is how ESP triggers the IFTTT (using IFTTTMaker) but not the other way around, meaning ESP get triggered from IFTTT service.
anonymous2
  • 4,902
  • 22
  • 49
guyd
  • 899
  • 17
If you want to send a "then that" trigger to your esp8266, you can use a webhook.
However, you need to do some preparations on your home network:
  • You need to have a webserver running on your esp8266.
  • You need to enable port forwarding on your router for one port to be forwarded to your esp8266.
  • You need to know your public facing IP-address or you need to use a DynDNS service.
  • You need to be aware about the security implications of opening a public facing port and forwarding this to your esp8266.
Here is what you then need to enter into the ifttt webhook action fields:
  • URL: enter your public facing IP-address (including port that is forwarded to the esp8266) or your dynDNS address.
  • Method/Content Type/Body: feel free to choose.
An example for a simple http call:
http://yourexternalip:yourport/msg?switch=0
Here is what you need to implement on your esp8266:
On the esp8266 you need to have the webserver check for a http request as configured in your webhook and react according to your wishes.
oh.dae.su
  • 560
  • 14
