I am working to connect my server to the clients via an MQTT broker. The MQTT client gets connected. But after publishing a message, the subscribe code receives a connection acknowledgment. The on_message() function never gets called.
I am stuck here.
I have pasted the subscribe client code and the output.
import paho.mqtt.client as paho
import time
client = paho.Client("local_test")
topic = "topic_1"
def on_log(client, userdata, level, buff): # mqtt logs function
print(buff)
def on_connect(client, userdata, flags, rc): # connect to mqtt broker function
if rc == 0:
client.connected_flag = True # set flags
print("Connected Info")
else:
print("Bad connection returned code = " + str(rc))
client.loop_stop()
def on_disconnect(client, userdata, rc): # disconnect to mqtt broker function
print("Client disconnected OK")
def on_publish(client, userdata, mid): # publish to mqtt broker
print("In on_pub callback mid=" + str(mid))
def on_subscribe(client, userdata, mid, granted_qos): # subscribe to mqtt broker
print("Subscribed", userdata)
def on_message(client, userdata, message): # get message from mqtt broker
print("New message received: ", str(message.payload.decode("utf-8")), "Topic : %s ", message.topic, "Retained : %s", message.retain)
def connectToMqtt(): # connect to MQTT broker main function
print("Connecting to MQTT broker")
client.username_pw_set(username=user, password=passwd)
client.on_log = on_log
client.on_connect = on_connect
client.on_publish = on_publish
client.on_subscribe = on_subscribe
client.connect(broker, port, keepalive=600)
ret = client.subscribe(topic, qos=0)
print("Subscribed return = " + str(ret))
client.on_message = on_message
connectToMqtt() # connect to mqtt broker
client.loop_forever()
And the output I get after publishing the message on the same topic is:
Sending CONNECT (u1, p1, wr0, wq0, wf0, c1, k600) client_id=b'local_test'
Sending SUBSCRIBE (d0) [(b'topic_1', 0)]
Subscribed return = (0, 1)
Received CONNACK (0, 0)
Connected Info
Received SUBACK
Subscribed None
Connected Info
EDIT 1:
Also, I am seeing that my broker has sent the message from the publisher to the client, but the client isn't able to receive it.
