I want to monitor the energy/power consumption of household appliances (for example an oven) by using a smart plug. The problem is that I cannot get the raw data to my computer. The measurements are usually plotted in a graph on a phone app, but what I need is the raw data in my computer (power, energy, time stamps..etc.). Does anyone have any idea on how to do this? Or which products allow this?
One solution would be with the help of Rasberry Pi. Make raspberry Pi as an access point and bridge the internet via the ethernet port. Make Rasberry Pi as your wifi connection to the smart plug. Now install Wireshark and collect all network data from the wireless interface in the form of pcap file. You can use SCAPY or Zeek(BRO) IDS for packet inspections or electric data reading.
Link:
Command to install wireshark: sudo apt-get install wireshark.
- 123
- 5
I have seen systems like this built using the TP-Link sockets with a raspberry pi that polls the sockets regularly enough to determine what mode a product was in (the product draws different amounts of current for different modes).
The problem will be monitoring an oven as these tend to be wired directly to high current supplies with no where to put a monitoring socket (They probably wouldn't be safe either).
You should be able to get a current clamp monitoring device to use for hard wired devices, but you would need to be able to clamp round the live line, not both the live and neutral
- 12,813
- 1
- 21
- 34
In 2024. If you are using a smart plug (say Zwave or Zigbee) with a smart hub, then the data is accessible from the hub.
I only have experience with the Home Centre (from Fibaro), where you can use rest calls, accessing the API to grab whatever data you want, including the raw data from the smart plug. I am sure that other smart hubs will have a similar facility.
If you don't want to use a hub, you can use something like a Z-Stick that plugs into an USB port on your desktop There are dozens of software that you can use to use the Z-stick. Or you can write your own.
- 507
- 2
- 3
- 18
