What would be the most appropriate LPWAN technologies for environmental monitoring in a remote area, given the following:
  • The monitoring system would be made up of 3 to 10 nodes located within a circular (star) pattern with a diameter of at least 5 km.
  • Each node sends data on a minute's basis.
  • The location is a rural/forested area on hilly terrain in Slovenia (southern central Europe)
  • The nodes should be energy efficient, however there is a possibility of connecting a central node (gateway) to mains power and the internet using Ethernet.
I am mostly looking into the following technologies:
  • GPRS (coverage in the area is not ideal, high energy consumption, sunsetting technology)
  • NB-IoT (not yet adopted by network carriers, unknown date)
  • Sigfox (no coverage, possibility of deploying a Micro Base Station)
  • Ingenu (most promising technology, no info on coverage or local base station possibilities)
  • LoRaWAN (no coverage, possibility of deploying a gateway)
Alexander
  • 131
Be aware that with LoRaWAN (and others ISM technologies), you have to follow the local regulation about duty cycle as you will use ISM radio band.
If you are at a distance of around 5km, you may need to use a large spreading factor meaning you will spread the data on air, and so use more airtime.
In Europe, you have (basically) 1% of air time allow. See this acticle
So to be able to send every minutes, you payload must be very short or you must use a smaller spreading factor, to comply with regulation. To get a idea you can is this spreadsheet
Tits
  • 171
I did a case study on LoRaWAN in 2015. Since then the community is continuously growing. The case study was about installing one Gateway in our city.
I find it one of the best solution because
R D
