This question also lives in the HA forum and r/homeassistant on Reddit
I run HA on 10.10.1.1 (this is a container) and my WiFi is on 10.10.2.0/24. To this WiFi is connected a Harmony Hub.
Following a writeup by @chubby92, I wanted to set up an emulated roku which would be configured on the Harmony Hub.
I believe that the Harmony Hub is scanning the network it is on looking for open 8060 ports so I set up a socat proxy on a device which is on the WiFi network (10.10.2.5) to bridge it with the HA container.
root@10.10.2.5 ~# socat TCP4-LISTEN:8060 TCP4:10.10.1.1:8060
This works fine (from any machine on the network):
root@srv ~# curl http://10.10.2.5:8060
<?xml version="1.0" encoding="UTF-8" ?>
<root xmlns="urn:schemas-upnp-org:device-1-0">
    <specVersion>
        <major>1</major>
        <minor>0</minor>
I therefore expected the Harmony Hub to now detect the emulated roku but I get an error, which says that Roku Roku 1 is not discoverable (or found, it depends on the context of the translation, my locale is French). It suggest to check that both devices are on the same WiFi (they are - indirectly) and proposes to either search again or ignore the IP analysis. Ignoring it adds the device but I have serious doubts it will work - I would like to be sure this is the expected outcome before digging in further.
UPDATE: yes, it does not seem to work. I listen to the HA events bus (by listening on all events in AppDaemon) and I do not see anything when choosing "Roku 1" on the Harmony remote, and trying to send something (say, Page Up, which is one of the first ones available)
Bence Kaulics
  • 7,843
  • 42
  • 90
WoJ
  • 865
  • 14
