I am doing a home automation project in which I should be able to control the lights on/off but more than that, the brightness of the lights.
I am using Home Assistant (not hassbian) and Node-Red along with MQTT.
I am using a normal bulb I purchased from a hardware store connected to a Sonoff ESP8266 and am able to use Node-RED to trigger a on and off state but am unsure how to trigger the specific brightness level.
Is it possible to control the brightness of any normal light that is made into a 'smart light' through the use of Sonoff? Or must they be devices that have that functionality made into the light itself.
(same for any other appliances, such as things such like a normal portable fan made into a smart fan through ESP8266 and controlling its speed.)
Aurora0001
  • 18,520
  • 13
  • 55
  • 169
Eric Lim
  • 161
No, you can't do that using Sonoff since it is an on-off switch with relay.
You need an Triac to do that. Normally the brightness control applications for AC will be done through Triac by changing the firing angle.
Electron
  • 196
No, most Sonoff devices are just remote controlled relays, they can only turn the power on or off.
You can not use them to dim lights.
hardillb
  • 12,813
  • 34
There are devices made specially for dimming using only on-off impulses to set the brightness. A common pattern is to use a short on/off signal for on/off, and a longer on/off signal to increase brightness in n % steps.
So provided you can make the Sonoff switch on and off sufficiently fast, and reliably to get the timing right, adding a device like this or any other similar impulse switch with dimmer should work.
(Note that I'm not suggesting to pulse-width modulate it - the shortest impulse necessary is ~0,5 sec. The output remains as set, until it receives the next command signal).
dlatikay
  • 119
